i have -03 excursion 6.0l and the milege is something un real 10-12 mpg under 50mph driving at normal finnish roads an maby i can get 13-14mpg on highway if i push it to going =) at speed 55-60mph....
i have the 100hp tune on.
what could be wrong..
u7165 9r12 get 10-12 mpg ??
RE: u7165 9r12 get 10-12 mpg ??
fuel filter?
injectors?
injectors?
juzatheman
Re: RE: u7165 9r12 get 10-12 mpg ??
about six months a go changed:mikel wrote:fuel filter?
injectors?
-all 8 injectors
-hi pressure pump
-icp sensor
-oil and filters (3 times)
this week:
-all filtters and oils what you can possible change.
no influense what so ever...
at cold outdoor temps (41f-32f) no power at all un till engine warms up to normal temp. if i push the pedal on the floor i couldnt catch up 1.0l nissan micra...
it is same acceleration speed if i push 1/2 inch the pedal or if i push it to the floor...
and the engine shakes and wobbles between 1150-2100 rpm
no trouble codes
something have to figure out before winter comes an it hits below -30f
p.s. no white or black smoke.
RE: Re: RE: u7165 9r12 get 10-12 mpg ??
How many miles are on it?Check your FICM output voltage to see if it is low.It should read 48.5v but no less than 38-40v when running.They had problems with the solder joints coming loose inside the module and low power will affect fuel mileage.It will also cause poor starting in cold weather.
juzatheman
i have a 7 pin fimc and the up left pin gives a reading 46v and the up right pin 11v.
how about the injector side there is a 4 wires/injector and only one wire 46v anothers 20v and less... is it normal? per injector
juzatheman
iwantmorepower
juzatheman
