100 hp tune
aperez78
RE: 100 hp tune
Post by aperez78 »
My truck does the same thing. (2006 f350 4x4 auto) This tune is designed to tow, not race so buy keeping the boost @ 20psi the egt remains much cooler. More torque, less hp
aperez78
RE: 100 hp tune
Post by aperez78 »
I just realized you were talking about the 100 hp tune, not the 40hp tune , sounded like you were talking about the 40hp instead. My truck with the 40hp tune only reaches 20psi boost won't pass that. The 100hp passes 30+psi you know these boost gauges from factory are not so accurate. hope that helps.
cole
Re: 100 hp tune
Post by cole »
mikem wrote:Was wondering if anyone else is only reaching 20 psi of boost when running this tune. I have a 2005 6.0 cc 4x4. Calibr. is VXCF4D5. Truck runs good other then that. The hand held is running the latest update. Cole do you have any explanation ?
What revision of the predator are you running? I will have to pull the tunes from that revision. Most likely is that they are not commanding much boost on that tune.
Cole Stevens
