U7194
RE: U7194
no idea... how old is it? if it's more than 2 years old, probably not...
RE: U7194
try it...
RE: U7194
well, then like mike said... try it...
if it doesn't work, I have the 9r08 revision file I can send you to get it back to working order...
but, try the new one... and lemme know...
RE: U7194
hehe...
sent...
sent...
RE: U7194
yes, absolutely... it's still a new enough revision where I have access to all the new tweaks that are in the newer revisions, so no worries... I can hook ya up...
install one of the tunes - either install the 87 octane tune if you only use 87 gas in your truck, or install the Diablo Tune if you use 91/93 octane gas in the truck...
then, all the info you need can be found at http://www.diablewtune.com
thx!
-Lew
thx!
-Lew
RE: U7194
well, it won't be specific for "towing"... overall performance, you'll get quicker throttle response, better acceleration, stronger/harder pull, etc etc... but nothing specific for towing... there's no tcm/tranny support, so can't adjust any tranny settings, like shift points or whatnot... you should have a tow/haul button that thing, no??
RE: U7194
no.. it is not octane specific....
the tow/haul mode just changes the shift points/firmness...
CANUCKPREDATOR
RE: U7194
Just get a Diablew tune and pull away. That's what I've got.
SparkySparks
RE: U7194
Agreed, get the DiabLew tune and you will be happy. When towing just use the tow/haul button and it will hold the shifts longer and firm them up for you and Lew's tune will still be giving you all the engine side improvements.
