U7193 WOT shift pressure
I have a diablosport U7193 for my 04 Silverado SS.. It has an option for part throttle shift firmness (+25/-25psi) and a WOT shift firmness (+25/-25psi).. if i want very firm shifts should i raise them all to max? or is that +25 psi too high and cause damage? I raised the WOT shift firmness to max at one point for a little while and the 1-2 shift still seemed sluggish but better than it was. Any help would be appreciated.
RE: U7193 WOT shift pressure
it's not in psi... those adjustments are in %....
going to max 25% won't damage anything...
if you need/want more adjustment than that, you'll need to get a custom tune done...
