traction control
ranger3801
traction control
Post by ranger3801 »
Can the trinity be used to turn traction control on/off on a 2005 pontiac gto? My predator wont do it, which is one of the main reasons I bought a tuner, but am willing to upgrade if I can find a tuner that will do what I want to do. The predator also will not raise or remove speed limiter, and canm only raise rev limiter by 400 rpm. Does anyone know specifics on what is and is not adjustable on trinity for a 2005 gto 6.0? Thanks.
RE: traction control
NO man...
as I responded in your other thread about it...
you can not do anything with the traction control via the programmer...
either press your button on the dash to turn it off, or get a custom tune done to have it permanently disabled in the custom tune...
what's your hang-up about the traction control?????
as for specifics on what is and what is not adjustable - they are the same... there is nothing tune-wise that is different from the trinity to the predator... they have the same capabilities...
http://diablosport.com/index.php?module ... lay&pid=63
if you can do it with the predator, you can do it with the trinity...
if you can not do it with the predator, you can not do it with the trinity...
HOWEVER! the trinity will have future updates available for it, that the predator will not... such as tcm/tranny support, and also the ability to be able to tune more than one vehicle at a time... plus, it already has more extra features than the predator has anyway...
and the speed limiter is not adjustable... it is already raised and at a set limit in the canned/preset diablo tunes... if you need it higher, then you need to get a custom tune...
Return to “Trinity GM Gas”
