custom tune upload to pcm
jmc1134
Post by jmc1134 »
trying to upload custom tune from preditor to pcm. need help. using a u7151, with v.9r11
RE: custom tune upload to pcm
https://www.diablosport.com/index.php?m ... ay&pid=187
the 7153 instructions would be the same... or:
"How To: Upload a Custom Tune to Your Predator or Trinity"
jmc1134
Post by jmc1134 »
i have the tune on the u7151, cant upload custom tune to my vehicle pcm
why not? are you getting errors??
you'd install it the same way as a regular diablo tune...
hook up to the car.. .make sure key is on...
select the custom tune, then Install Tune...
jmc1134
Post by jmc1134 »
i plug it in, select options, then select custom tune, then the options are import custom tune, export original backup, export last written, and erase custom tune. the first three options sayexports should be started from the dsdownloader. this menu selection is obsolete. return to the main menu and then import from downloader
nooooooo.... you don't go into options to install the custom tune to the car...
you already have the custom tune imported into the predator, right???
so hook up to the car, and if Custom Tune isn't right on the main menu, then go into Performance Tune - then Custom Tune...
jmc1134
Post by jmc1134 »
thanks that was my problem
Return to “General Support”
