SD Card support now available!
SD Card support is now available with the latest Trinity update!
The new update is trinity_gm_can_gas-1r07a_update.crom
and be sure to also update to the latest DSDownloader version 2.2.2.2....
You can use up to a 2GB sd card...
make sure the trinity is off before inserting an sd card...
you can use the sd card for saving data logs to it, save custom tune files to it, save your custom gauge dashboards to it, get the copies of your original backup and last tune written tune files to it, etc etc...
jimb
RE: SD Card support now available!
Post by jimb »
Actually, IF you let DSDownloader update itself to 2.2.2.2; It will automatically install all the newer CROMs (if your Trinity is unmarried).
orspg
Post by orspg »
Lew, Domenic Signorelli here. I got a big problem, I just updated my crom to trinity_gm_can_gas-1r07b_update.crom and it won't let me select the escalade. It goes as far as the 6.2L and returns,"if you're unsure of the engine, please call customer support". and a whole bunch of other stuff. What happened? How do I fix it?
2015 Silverado 3500 HD Crewcab LTZ, Dually, Duramax/Allison 4X4
well, do what it says man... call tech support tomorrow... hehe...
I dunno man... you shouldn't have any issues...
did you restore the original backup to your truck first??
did you try updating your Trinity again??
orspg
Post by orspg »
Yup! Don't know what happened. I tried 3 times to update it and each time it stops at the engine selection part and keeps repeating itself and never goes beyond that.
not sure man... gonna have to call tech support... the earlier the better, that way you're not on hold as long...
call about 9:30 / 10 AM...
1-561-908-0040
pick a different engine ;)
Anders_Y
Post by Anders_Y »
I can't seem to get the SD card to work. The unit won't start up with the 2GB (standard not HC) SD Card in the slot. Does it need to be pre formatted in any specific way? I'm pretty sure I've applied all the incremental updates. Should I apply "trinity_gm_can_gas-1r07a_update.crom" again?
-Anders Y, Los Angeles, CA
2009 GMC Sierra XFE (SLE) Crew Cab, 5.3L
* DiabloSport Trinity
* Banks Ram Air intake
* Edelbrock 3" Cat-back Exhaust
* JBA Shorty Headers
1989 Mitsubishi Montero 4 Door, 3.0L 4x4
* Pending twin turbo conversion
Anders_Y
Post by Anders_Y »
Upon trial and error, I found that the card needs to be formated in windows as FAT and FAT only, not FAT32, and not FAT/master boot record from mac. It works!
mulisha911
Post by mulisha911 »
How to video: DiabloSport Trinity
Tutorial - How to install tunes onto your SD Card
The link: http://www.youtube.com/watch?v=e8kqDWgvCm4
moatazali
Post by moatazali »
Video has been removed, please re-check
davecarpe
Re: SD Card support now available!
Post by davecarpe »
Can you use larger than a 2GB SD card?
It is actually harder to get the 2GB cards and i just got some 8GB cards for $5 :idea:
no... 2gb is the limit...
garrett
Site Admin
Post by garrett »
unfortunately not. the tool does not have that ability.
sinistersf
Post by sinistersf »
Can we send you guys an SD card to have custom tunes put on after we make mods beyond normal bolt on mods? Such as a cam?
"It's better to burn out, than to fade away"
Return to “Trinity GM Gas”
