Page 1 of 2
2011 chevy 6.0 support
Posted: Sun Dec 19, 2010 10:03 am
by teddy75840
I have u7194 and just purchased for 2011 truck because i was told it would work. When booting is says 2007 to 2011. Why doesn't it work if it says it will?
RE: 2011 chevy 6.0 support
Posted: Sun Dec 19, 2010 11:14 am
did you update the predator to the latest crom revision update that actually has 2011 support in it???
you can find it here:
http://diablosport.com/index.php?name=P ... 431#158431
Posted: Sun Dec 19, 2010 11:28 am
by teddy75840
Yes. U7194-9r18.crom
Posted: Sun Dec 19, 2010 11:34 am
by teddy75840
Posted: Sun Dec 19, 2010 12:18 pm
no... 9r18 does not... that is NOT the latest with 2011 support in it... did you even go to my link???
u7194-9t19a.crom is the lastest with 2011 support in it...
Posted: Sun Dec 19, 2010 12:44 pm
by teddy75840
Ok went to link. Updated u7194 to that. Now getting a message failed cut. Error (-1) something about seed
Posted: Sun Dec 19, 2010 2:38 pm
have any aftermarket things installed on the truck?? like, stereo, alarm, remote start, trailer brake, etc etc?? if so, it would need to be totally disabled / unplugged / disconnected / fuse pulled for it...
have the key turned on (but engine not running)??
Posted: Sun Dec 19, 2010 4:14 pm
by teddy75840
Posted: Sun Dec 19, 2010 4:21 pm
yeah, I know... you posted that before...
so...
Posted: Sun Dec 19, 2010 5:30 pm
by teddy75840
No. Brand new truck. I took out all appropriate fuses and had all doors shut. No lights on. No aftermarket parts. It tries several seconds. Then the hour glass pops up. When that happens it disables 4x4 and antilock brakes.then counts seconds several more times. Then kicks out and says failed cut.
Posted: Sun Dec 19, 2010 5:32 pm
if you are completely stock and no aftermarket items installed in the truck, then there is no need to pull any fuses...
THAT could be the issue as well...
put all the fuses back in...
start up the truck for a few seconds, then shut it off...
then, connect the predator up, put on the parking brake, turn your key to on... and try it again...
Posted: Sun Dec 19, 2010 6:38 pm
by teddy75840
Same results. Failed cut. PCM error root cut (-1)
Posted: Sun Dec 19, 2010 6:43 pm
by teddy75840
I know I'm being a pain in the a**. Is there any thing else I can try? And thanks for your help. I've had a dodge tuner and a GM tuner on a 08 chevy. Never had these problems
Posted: Sun Dec 19, 2010 7:46 pm
sorry man... nothing else that I can help ya with right now... I'll do a search through the forum and see if I can dig anything up...
you'll need to wait until the diablo guys are back in the office tomorrow... they should be able to help ya more and have more ideas...
thx man...
by teddy75840
Thank you.
