Rev limit in gear
Posted: Fri Dec 31, 2010 2:28 pm
by 6gear
What is this, I have adjusted mine to max setting and truck still shifts around 5400 rpm's.
RE: Rev limit in gear
Posted: Sat Jan 01, 2011 12:08 am
by 6gear
So nobody knows?
Posted: Sat Jan 01, 2011 8:15 am
by southbeach
i´m also interested what does this option mean or help to tune my car becasue i can not get rid of the speed limiter in my 09 yukon denali with the software release r18
Posted: Sat Jan 01, 2011 11:51 am
if you want to hit the higher rev limit you set, then you have to shift the vehicle manually... if you just put it in Drive and go, it will still shift at it's normal rpm's...
have to manually shift to hold the gears longer in order to get to the higher rpm limit you set...
Posted: Sun Jan 02, 2011 11:12 am
by 6gear
That explains why it didn't make any difference in auto mode, thanks
