Can I get 9r11 crom?
I tried to update my predator and it did the same thing as so many others on here. Thanks My predator is the U7186. Thanks guys
RE: Can I get 9r11 crom?
Emailed you the last update that would work with the rail pressure and timing. Good luck here the latest file posted was in 8/10 and still will not work with the early 2007, Diablo's support hangs by a thread anymore
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
Predator u7186
Damon
And mine still wont update , with what you sent me. WHY!!!! Come on guys make your tools work!!!!!
07 Chevy, LBZ crew cab, LT-2.
Performance Exhaust.
Moto Metal, Skulls
285/70/17" BFG, KO's
Moto Metal, Skulls
I think you need to follow the info from this topic:
http://diablosport.com/index.php?name=P ... ic&t=24968
Reboot instructions are in post 5 on the first page and the update file that seems to work for most guys (9r08) is on the 3rd page.
Then use the crom I sent you
Predator u7186
Damon
Predator u7186
Damon
Precise steps to fix a Predator with an "Application Missing or Corrupt" message:
1. Download and install the latest DS Downloader from HERE
2. Download the latest CROM file for your predator from HERE after selecting your Predator part.
3. Connect the Predator to the PC but do NOT power it on yet.
4. Run DSDownloader on your PC.
5. From the Options menu, choose Auto Detect to un-check it (Auto Detect cannot work with a corrupt Predator).
6. Click on the "Express Tune Mode" tab at the bottom.
7. Select the appropriate COM port and baud rate settings on the toolbar (the defaults are probably correct, but these may need tweaking).
8. Click on the "Send CROM file to Predator" button.
9. Select the CROM file that you downloaded earlier.
10. Now power up the Predator.
11. After a couple of minutes your Predator should reboot and no longer be corrupt.
Predator u7186
Damon
Predator u7186
Damon
