ABS problems, Different sized tires front and rear
97fordrunner
Post by 97fordrunner »
I have a 2008 silverado with 4.8L V8. I have larger tires on the back than on the front will the Diablo U7194 allow me to correct the speedometer, lack of tire pressure sensors, and antilock brake problems. I am especially interested in getting the antilock brakes working again.
RE: ABS problems, Different sized tires front and rear
nah, won't fix that, because you have different sized tires front and rear... so one set is always going to be off, so you will still have the ABS problems...
you need to have all 4 tires the same size man...
the tunes do nothing for tire pressure sensors.... that's not an ecm/engine tune issue.. that's a BCM (body control module) system... check with your dealer and see if they can do anything about it... most likely not...
neonhomer
Post by neonhomer »
The dealer could probably flash you BCM with a different program w/o TPMS.
NeonHomer
1996 Jeep Grand Cherokee I6 4.0
CANUCKPREDATOR
Post by CANUCKPREDATOR »
they won't disable tmps, as it is a safety feature.
