Page 1 of 2
Repeat DTC's with Extreme Power Puck 2011 Dodge 6.7
Posted: Thu Feb 24, 2011 8:46 am
by Bambam-x
I have a p1040 EPP on my 2011 Dodge 6.7 Cummins and keep getting various injector trouble codes (p020e for example) and a p0606 code. I reset the codes and they come back in a couple days, remove the EPP and no codes. Also noticed that when it does tgorw these codes, there is a loss in power and can not notice any change in performance with the EPP adjustment. Any help?!?!?
RE: Repeat DTC
Posted: Thu Feb 24, 2011 11:04 am
by frankl
Discount the negative battery cable for a few minutes before installing the EPP.
RE: Repeat DTC
Posted: Thu Feb 24, 2011 11:09 am
by Bambam-x
So should I uninstall the EPP, run the truck, clear all codes and then try this? Do I need to disconnect the battery to return to stock or will that matter as much? Thanks
RE: Repeat DTC
Posted: Thu Feb 24, 2011 11:14 am
Yes, uninstall, disconnect battery, connect puck, and reconnect battery.
Posted: Tue Mar 01, 2011 4:56 pm
by Bambam-x
Is there any chance that the EPP could throw either of these codes: p0101 and p2bac ?
Posted: Tue Mar 01, 2011 5:48 pm
Do they only appear with the puck installed?
Posted: Tue Mar 01, 2011 6:32 pm
by Bambam-x
Yes, already did the steps listed earlier. Codes came on within 1 day of clean re-install, cleared the codes and they came back after 3 days.
Posted: Tue Mar 01, 2011 7:08 pm
Does the truck appear to run OK with the puck installed?
Posted: Tue Mar 01, 2011 7:31 pm
by Bambam-x
Runs okay, but cant really tell much if any change with the dial adjustments.
Posted: Wed Mar 02, 2011 4:05 pm
by Bambam-x
Runs okay, but cant really tell much if any chafe with the dial adjustments.
Posted: Wed Mar 02, 2011 4:07 pm
still looking into this.
Posted: Wed Mar 02, 2011 8:44 pm
by Bambam-x
Threw the codes again today and added p020d also???
Posted: Mon Mar 07, 2011 4:39 pm
by Bambam-x
Any updates??? Still throwing codes, the more I turn down the EPP the longer it takes to throw the codes. ?!?!?!?!?
Posted: Mon Mar 07, 2011 5:06 pm
Could the fuel filter be clogged?
Posted: Mon Mar 07, 2011 5:32 pm
by Bambam-x
Truck only has 2000 miles, you sure about this? And no codes when EPP removed?
