Repeat DTC's with Extreme Power Puck 2011 Dodge 6.7
PowerPuck/Extreme PowerPuck Support
Bambam-x
Post by Bambam-x »
I have a p1040 EPP on my 2011 Dodge 6.7 Cummins and keep getting various injector trouble codes (p020e for example) and a p0606 code. I reset the codes and they come back in a couple days, remove the EPP and no codes. Also noticed that when it does tgorw these codes, there is a loss in power and can not notice any change in performance with the EPP adjustment. Any help?!?!?
frankl
RE: Repeat DTC
Post by frankl »
Discount the negative battery cable for a few minutes before installing the EPP.
Bambam-x
RE: Repeat DTC
Post by Bambam-x »
So should I uninstall the EPP, run the truck, clear all codes and then try this? Do I need to disconnect the battery to return to stock or will that matter as much? Thanks
RE: Repeat DTC
Yes, uninstall, disconnect battery, connect puck, and reconnect battery.
Bambam-x
Post by Bambam-x »
Is there any chance that the EPP could throw either of these codes: p0101 and p2bac ?
Do they only appear with the puck installed?
Bambam-x
Post by Bambam-x »
Yes, already did the steps listed earlier. Codes came on within 1 day of clean re-install, cleared the codes and they came back after 3 days.
Does the truck appear to run OK with the puck installed?
Bambam-x
Post by Bambam-x »
Runs okay, but cant really tell much if any change with the dial adjustments.
Bambam-x
Post by Bambam-x »
Runs okay, but cant really tell much if any chafe with the dial adjustments.
still looking into this.
Bambam-x
Post by Bambam-x »
Threw the codes again today and added p020d also???
Bambam-x
Post by Bambam-x »
Any updates??? Still throwing codes, the more I turn down the EPP the longer it takes to throw the codes. ?!?!?!?!?
Could the fuel filter be clogged?
Bambam-x
Post by Bambam-x »
Truck only has 2000 miles, you sure about this? And no codes when EPP removed?
Return to “PowerPuck/Extreme PowerPuck”
