Repeat DTC's with Extreme Power Puck 2011 Dodge 6.7
I have a p1040 EPP on my 2011 Dodge 6.7 Cummins and keep getting various injector trouble codes (p020e for example) and a p0606 code. I reset the codes and they come back in a couple days, remove the EPP and no codes. Also noticed that when it does tgorw these codes, there is a loss in power and can not notice any change in performance with the EPP adjustment. Any help?!?!?
frankl
RE: Repeat DTC
Discount the negative battery cable for a few minutes before installing the EPP.
RE: Repeat DTC
So should I uninstall the EPP, run the truck, clear all codes and then try this? Do I need to disconnect the battery to return to stock or will that matter as much? Thanks
RE: Repeat DTC
Yes, uninstall, disconnect battery, connect puck, and reconnect battery.
Do they only appear with the puck installed?
Does the truck appear to run OK with the puck installed?
still looking into this.
Could the fuel filter be clogged?
