Modifying Stock Tune/ Spark Advance
U7146 Rev 9r07
2002 Mustang GT Auto
I want to increase the timing on the stock tune but I don't want to get to the advanced degree that the 87 Octane canned tune is at since I get high rpm pinging. What is a safe value to increase the stock timing to get some more performance without getting to the level of the 87 tune?
I have been driving with a .5 degree increase in 2k-4k and 4k-7k with no ill effects. How far advanced is the 87 Octane tune over stock?
Thank you.
Thank you.
2011 Ford Crown Victoria LX
Stock for now...
Stock for now...
RE: Modifying Stock Tune/ Spark Advance
install the 87 tune and subtract timing in 4k-7k untill the pinging stops
EVOLVEDNOTTAMED
I think Mike posted in another topic a little bit lower about the samething.
"OK, well, maybe 2-3* generally."
http://diablosport.com/index.php?name=P ... dfd2cd3909
Can check the post to make sure tho.
EVOLVEDNOTTAMED posted there as well so, can wait on Mike to give a % if you want or can try and figure it out.
Not sure myself on a good safe number.
EVOLVEDNOTTAMED
EVOLVEDNOTTAMED
EVOLVEDNOTTAMED
timing is 20* at WOT, so to get 2* you need to add 10%, in your case lower timing at 4k-7k by 10% to remove 2*
I would suggesting running the 87 tune, and use 91 octane to see if the pinging goes away. It really should ping with the 87 tune, because Diablosport canned tunes aren't very aggressive, which is good for the majority of people.
EVOLVEDNOTTAMED
EVOLVEDNOTTAMED
EVOLVEDNOTTAMED
