Bad Knock Sensor question ...
pcguy760
Post by pcguy760 »
If I have a bad / intermittent knock sensor, is it advisable to use the Predator on my truck or should I fix the knock sensor first and then only use it? The issue with my knock sensor is that sometimes the truck falls flat on its face under acceleration and I was told that it was the knock sensor (error code)...
chiphamons
RE: Bad Knock Sensor question ...
Post by chiphamons »
You need to fix the problem as it will just keep pulling more timing and won't notice the gains that are possible! It's not an expensive fix. Once you get if fixed then download the tune and enjoy.
6.2L GMC Sierra Texas Edition!
Hooker Muff
K&N CAI
Tuned
pcguy760
Post by pcguy760 »
Got the sensor issue fixed - now waiting on my Predator to show up :)
