NEW TO THE DEISEL WORLD...HELP ME PLEASE.
Posted: Mon Jul 30, 2007 4:26 pm
by FASTBIKE
I JUST GOT A U7131 PROGRAMMER FOR MY 06' DODGE MEGACAB 3500 SINGLE AXLE...Ii TRIED THE TOW MODE THIS PAST WEEK-END AND WOW...IT WORKED GREAT.
WHAT IS THE BEST SETTING FOR DAY TO DAY RUNNING WITHOUT THE TRAILER...THE TRUCK IS STOCK EXCEPT FOR AN K&N INTAKE KIT.
MY REAL QUESTION IS IN REGARDS TO THE EXTREME RXL TUNE...IT SAYS TRANSMISSION MODS ARE REQUIRED...WHAT MODS ARE REQUIRED...AS I DONT WANT TO BLOW UP MY NEW TRUCK....
IS THE STACKER WORTH THE MONEY...AS I OPTED OUT AND JUST GOT THE PROGRAMMER. BECAUSE I WAS NOT SURE WHAT IT REALLY DID.
WHAT ELSE WOULD BE GOOD TO GET TO MAXIMISE THE PERFORMANCE OF MY PROGRAMMER..OR WHAT ELSE SHOULD I RUN TO BE ON THE SAFE SIDE.
THANKS IN ADVANCE,
MR. NEW GUY
RE: NEW TO THE DEISEL WORLD...HELP ME PLEASE.
Posted: Mon Jul 30, 2007 4:35 pm
by ncyz1v
on the safe side use a exaust guage....remove the resonator or "cat" if its to hot! or go with a mandrell bent full exaust.
the perf. tune was my best fuel milage but that is diff. for some.
Posted: Mon Jul 30, 2007 5:41 pm
by Dodgezilla
You will need a minimum of a better converter and valve body. That's for starters. You really need a fully built trans to run that all the time. Your truck is probably making around 425-430rwhp on the Extreme RKL tune. That's a lot for the stock trans to handle...
As for the Puck, just keep what you have! It runs better and rail pressure is much lower w/ just the Predator...
Posted: Mon Jul 30, 2007 10:32 pm
by duallydave
i second the reply on no puck,the pred works fine on its own.with a stock auto maybe try the stacker tunes,stacker extreme with no puck is good for milage.
Posted: Tue Jul 31, 2007 10:28 pm
by cameroneod
I personally love the puck. I hated it when I first got it (felt like I paid for something I didnt need, and never used) but when towing its really nice to be able to flip a switch for a little more oomph.
Posted: Wed Aug 01, 2007 3:15 pm
by FASTBIKE
THANKS FOR ALL THE HELP GUYS,,,REALLY. I NOW HAVE ANOTHER QUESTION CAN I SAFELY RUN THE EXTREME SETTING WITHOUT DOING ANY MODS TO MY TRANS ORTRUCK,. OR DO I NEEAD A GUAGE OF SOME SORT OR JUST LEAVE IT ON THE PERFORMANCE SETTING...I KNOW THE EXTREME RXL SETTING IS OUT UNLESS I DO SOME TRANS MODS.
LET ME KNOW....THANK
P.S. ANY OTHER QUICK AND DIRTY TIPS FOR MORE POWER !!!
Posted: Wed Aug 01, 2007 5:26 pm
by Dodgezilla
If you want to be safe then stick to the tow tunes. Anything higher will deteriorate your trans eventually...
Go to
www.dieseltruckresource.com to answer all your questions about other mods for your truck. BEWARE though!!!! Once you start you can't stop!!!!
Posted: Wed Aug 01, 2007 9:07 pm
by duallydave
an egt gauge is a must with anything higher than performance.temps can climb real fast.ur tranny may not like extreme if ur hardon it.
Posted: Wed Aug 01, 2007 9:10 pm
by duallydave
Posted: Wed Aug 01, 2007 9:25 pm
by Dodgezilla
Posted: Wed Aug 01, 2007 10:35 pm
by madmanwithmouse
Also, if I run my puck alone and stay in it, it will climb to 1300 at 70ish and keep going higher if I didnt let up. The tow tune is my favrite for generl driving and trailer pulling, good throttle responce but it is also smooth. Not to mention the egts won't go much above 1000(preturbo). I get 17ish mpg but could do better if my foot would just listen to me
I guess it just likes to watch the cloud-O-Smoke.
Posted: Thu Aug 02, 2007 4:53 pm
by FASTBIKE
I ASKED THE GUY AT THE STORE WHERE I BOUGHT MY PRED ABOUT RUNNING ON EXTREME MODE AROUND TOWN...AND HE TOLD ME NO PROBLEM...WHAT DO U GUYS THINK....I DONT HAVE AN EGT TEMP GUAGE OR ANYTHING LIKE THAT.
THX,
SPIKE
Posted: Thu Aug 02, 2007 5:28 pm
by madmanwithmouse
Id say so long as you are not in it very hard you should be fine tranny and egt wise, but if you get in it relly hard you are most likley gonna have a toasty engine.
