02 mustang gt w/procharger & mafia
Posted: Wed Mar 30, 2011 4:53 pm
by lm11m
Should maf reading on scanner with koeo be same as stock parameter .6-1 volt ? Mine's reading 5.12 and running poorly. Need info asap . Thanks
RE: 02 mustang gt w/procharger & mafia
Posted: Wed Mar 30, 2011 5:11 pm
its a 0-5 V sensor, you should not be seeing that much voltage.
What does it look like at idle?
Do you have a MAFia installed?
Posted: Wed Mar 30, 2011 5:19 pm
by lm11m
Yes, MAFia is installed. If I take out of system car will idle normally
Posted: Wed Mar 30, 2011 5:34 pm
no, that wont help, you need it there if the tune is set up for it.
Id rma the mafia if voltage is not right at idle.
Posted: Wed Mar 30, 2011 5:36 pm
by lm11m
what's your procedure,
bought car with unit installed
