U7131 Not supported
Posted: Tue Apr 19, 2011 5:19 pm
by Callbeck1
2006 Dodge 5.9l 3500. Restored original backup. Downloaded new crom file 9r07. Tried to install tune and now it says, Vehicle not supported?
RE: U7131 Not supported
Posted: Tue Apr 19, 2011 5:22 pm
What is the calibration ID it gives you?
Were you at the dealer recently?
Posted: Fri Apr 22, 2011 4:51 pm
by Callbeck1
Does not give me a call id. Does not show VIN or HEX numbres either. Last tune written was original back up. Truck has not been back to dealer.
Posted: Tue Apr 26, 2011 12:33 pm
by Callbeck1
Any ideas on this?
Posted: Tue Apr 26, 2011 12:59 pm
If there is no calid showing, you need the dealer to reflash the PCM properly
Posted: Mon May 16, 2011 9:41 pm
by orejim
301129
v.9t07a
When I connect to the truck it boots up, tells me to turn key on, then I hit Performance Tune, it does its thing then tells me "Your vehicle not in our database.Contact dealer for free update" CAL_ID 50325053AB. Vin comes up correct.
Whats going on, I should have the latest updates.
orejim
2006 dodge RAM 2500 5.9
Posted: Tue May 17, 2011 11:28 pm
by REESER
I have the same issue and cal Id. I been trying to get them to add this cal for over a year swell as others so I feel your pain. See my posts under reeser and do a search and u will see. I hope you can get them to get it addded because I can tell u that is the current download from dealer cus I have checked and there is several if us waiting for the same answer. Hope u don't give up like some on here have. Good luck. I am with ya I have the same money rapped up in the tool and can't even use it.
U7131 not supported
Posted: Wed May 18, 2011 12:47 am
by orejim
Reeser, went straight to the Tech people.I had v.9t07a loaded in the tool. They had me go back to v.9r07which i had already tried and it didn't work then, but I thought what the hell. So I reloaded it with the old load and tried it on the truck and, guess what it didn't work. Now I am really gun shy so tommorow I get ahold of the people I bot it from (truck customizers) and it goes back.
Good Luck!!!
RE: U7131 not supported
Posted: Wed May 18, 2011 9:59 am
can you guys post up your VINs?
Posted: Sun Aug 07, 2011 12:36 pm
by shotime03
I'm having the same problem. My Cal ID is 45325853AB, my VIN is3D7KS29C97G715477, the HEX is showing- 3344374b53323943393747373135343737. It is telling me (3) this tool is not registered for this vehicle, but I have had it on here for a month with no problem. All of a sudden it will not work at all. It let me install my factory backup, but that was all it did. I had it set to Performance. What can I do to fix this problem?
