How do I see my air fuel/ratio on Predator
I have an a 1999 SS, I just purchased the SLP version of the Predator, I have looked at the real time data, but no where does it show what the air/fuel ratio is, just the short term and long term trims.....I'm a newbie so understand.
The guru's here will probably tell you that some Preditor models will display A/F ratios and some wont.
Regardless, the narrow band sensor in your car is incapable of giving an accurate reading at anything other a small window on either side of 14.7, so any other value displayed by the Preditor is a rough estimation... at best.
Look about half way down this page:
http://www.innovatemotorsports.com/resources/news3.php
Westx07zo6
Read the tuning " Sticky"at the top of the opening page. Did you try going to the Diagnostics menu then choose Real Time Data then select "gas general short" scroll down and select Air Fuel Ratio.
08 Viper GTS Blue Coupe- Belanger header system
05 SRT-10 Ram rc- Bassani headers, B&B mids, DC tuned PCM, K&N cai, B&M sport shifter,duel elect. fans.
08 Ford F-250 SuperCab 4x4 6.8L V10
03 Hemi Ram QC (modded)
when you go to monitor the real time data, you should have Air Fuel Ratio or Equivalence Ratio as one of the parameters to moniitor... if you don't have that in your parameter list, then you can not monitor it...
