Page 1 of 2
surge
Posted: Thu Jun 02, 2011 2:22 pm
by mchemi426
started to notice a surge in my idle when slowing down the surge happends when the idle goes to 1100 rpm when jumps up 200 rpm does anybody have this prolem thanks
RE: surge
Posted: Thu Jun 02, 2011 2:46 pm
by Mike_Levy
I've been having the exact same problem, but nobody knows why. Even when stopped, the motor will surge and i'll have to lean on the brakes to keep from rear ending the guy in front of me.
RE: surge
by Mike_Levy
RE: surge
Posted: Fri Jun 03, 2011 10:57 am
by mchemi426
i think it started after the new version.9R28 was installed will try to go to stock mode and see if it does it
RE: surge
Posted: Fri Jun 03, 2011 2:07 pm
by Mike_Levy
I'm running 9r12 with a CMR, so its not 9r28 related.
RE: surge
Posted: Fri Jun 03, 2011 3:18 pm
by mchemi426
Going to try it anyway I already put it in stock mode going for a long rider this weekend let u known
RE: surge
by mchemi426
RE: surge
Posted: Fri Jun 03, 2011 4:16 pm
by julan
things would do contribute:
1. TB is dirty and needs to be cleaned.
2. Fuel trims, please do record a log and post it.
RE: surge
Posted: Fri Jun 03, 2011 5:18 pm
by Mike_Levy
Chrysler does not allow you to clean the TB. Its says DO NOT CLEAN on the side. I clean them all the time before sending out for porting, but they say not to.
I know for a fact my fuel trims are messed up. Johan just sent me a tune with them adjusted. That explains my issue, but what about all the others? Everybodys fueling can't be off.
RE: surge
Posted: Fri Jun 03, 2011 7:55 pm
by PlumCrazyDaytona
Here is what worked on my car, try a little less inverse on the ETC in your tune. My fuel tables are dead on and I had this issue, when my ETC was loosened up but with less ETC and my surge is gone for the most part, it does show up everynow and again but very rarely I also bumped up my idle and with the idle increased the problem is all but gone
Re: RE: surge
Posted: Sat Jun 04, 2011 12:16 am
by julan
Mike_Levy wrote:Chrysler does not allow you to clean the TB. Its says DO NOT CLEAN on the side. I clean them all the time before sending out for porting, but they say not to.
Come on, if the TB full of dirts do u think will keep it like that !!!
Leave it to cool down, gently clean the internal wall of the TB.
RE: Re: RE: surge
Posted: Sat Jun 04, 2011 4:16 pm
by Mike_Levy
Fixing the fuel trims didn't fix the problem on mine. Its still doing it just as bad, if not worse. In traffic this afternoon the damn thing was stuttering like it had a misfire, then once the road opened up, it was perfectly fine.
RE: Re: RE: surge
Posted: Mon Jun 06, 2011 1:15 pm
Mike, you dont want to hear this, but could you have a cracked ring land maybe?
Have you done a compression or leak down test?
Re: RE: Re: RE: surge
Posted: Mon Jun 06, 2011 2:42 pm
by Mike_Levy
mikel wrote:Mike, you dont want to hear this, but could you have a cracked ring land maybe?
I was thinking it could be a short block problem. I haven't tested it yet.
I still have the damn transmission sitting in the garage waiting to be installed, having to tear down the short block would seriously make me consider selling the truck. How long until that BMW support? An X5M sure sounds good now. :twisted:
Posted: Mon Jun 06, 2011 3:01 pm
I keep hearing little chirps about BMW here and there...
