will the u7137 work on the 2011 jeep jk
TYPHOON4X4
i realize the u7137 will work up to model year 2010 but i think the 2011 has some program changes and needed to know if i could use the tuner for 2011 jeep jk unlimited?
RE: will the u7137 work on the 2011 jeep jk
No, 2011s are not yet supported.
TYPHOON4X4
So would you recommend buying u7137 and wait for an update or will an entirely new programmer come out?
jaimeson55
Re: RE: will the u7137 work on the 2011 jeep jk
TYPHOON4X4 wrote:So would you recommend buying u7137 and wait for an update or will an entirely new programmer come out?
I am 99.9999% sure it will be the same u7137 at least until OBD3 or Japan's next earthquake.
RE: Re: RE: will the u7137 work on the 2011 jeep jk
Dont hold your breath.
U7137 is pretty full as it is, and with the new changes to the 2011 PCM, there is no telling if the Predator will even be able to talk to it
Re: RE: Re: RE: will the u7137 work on the 2011 jeep jk
That's not what i wanted to hear! Would it be possible to send in our U7137 and get it flashed to work with the 2011 PCM? I don't mind waiting but due to personal issues money is extremly tight!mikel wrote:Dont hold your breath.
RE: Re: RE: Re: RE: will the u7137 work on the 2011 jeep jk
Nope. If it doesn't work with the U7137, then the hardware will be different and no amount of flashing will make it work.
They have nothing for the 2011+ anyway. They are still working on it. The new PCM's are a bit of a PITA to say the least!!!
2013 SuperBee......................................................
