Installed Powerpuck in 2009 Jeep 3.0. Everything was fine for a month, then customer comes back with 3 dtc's and the truck in limp mode.
I got an RMA and sent the puck in to look for troubles, it got the all clear and diablo sent it back.
While the puck was not in the truck, no DTC's were set. I re-installed it and it set the DTC's after a day of driving.
DTC's:
P0191 Fuel rail presure sensor circuit performance
P0193 Fuel rail pressure too high
P0087 Fuel rail pressure too low
Has anyone else had this issue?
The puck basicly raises fuel pressure by fooling the ecm, right? What tells the ecm that the fuel rail pressure is still right?
Puck problems with Jeep 3.0
Seth Patterson
FederalPerformance.ca
RE: Puck problems with Jeep 3.0
looking into this Seth.
Thanks, Mike-
The customer is pretty anxious so let me know if I can do anything to help, like scanning parameters or what-not with the puck installed.
These diesels are pretty popular up here in Canada, sure would like to have some tuning ability for them- hint-hint.
Seth Patterson
Here is the reply from our puck engineers:
If the fuel rail pressure sensor is reading too high and too low then I think there has got to be a loose connection somewhere in the harness. For it to show both then it is loosing the signal. It is probably not a broken wire, just a bad connection since it is not coming on at start up.
Lets get an rma going and get the whole unit back here so we can test the harness with the puck and get it fixed.
Thanks, I'll pull the harness out and send it in.
Seth Patterson
send the whole thing if possible Seth, makes it easier to test it all at once
we have the puck in our jeep now for 6 months. no power in crease or fuel milage. not happy at all
no changes at all?
You can surely send it in for a warranty check...
NO CHANGES whats so ever!!!! Also took back to retailer with in 2 weeks to return they wouldn't take back now i'm stuck with something doesnt work have to pay to ship back!!! never improved fuel mileage or performacnce also does anyone know where to get delete pipe for jeep 3.0 crd?mikel wrote:no changes at all?
guess theres not on this topic at all!!
