Page 1 of 2
C6 LTFT Question using 7194 and the new update 8r07
Posted: Mon Aug 13, 2007 9:03 pm
by MikeBotz
I have a 2006 C6 with the A6. I logged data with my laptop (Diablo only does about a minute of logging)
After Logging about 50 minutes of data I have 216K lines of data in Excel. It took a while for the macros to run. After running them I now have almost 93,000 lines of data.
Now when I do my LTFT Average there is over a little over a 1 difference between LTFT Bank 1 and Bank 2. 4.08 to a 2.97
Should I use the average of the 2? I don't think there was a setting for each bank when I looked.
Would anyone with a little more experience like to take a look at my file to see if I did it right?
My 02 seems way out of range also. The average is .508 and .506. I am not sure if averaging the 02 tells me anything, but when checking it a in a few places at WOT it is in the low .8 range
Thanks, Mike
RE: C6 LTFT Question using 7194 and the new update 8r07
Posted: Mon Aug 13, 2007 9:15 pm
Interesting.
You can use an average of the LTFTs from one bank to the other to base your adjustments.
The O2s will constantly vary at part throttle, but low .8XX seems a bit low at WOT.
What gear/rpm were you doing the logs at?
Posted: Mon Aug 13, 2007 10:11 pm
by MikeBotz
I don't remember what gear, probably 4th or 5th and about 2200 was one spot I just looked at. There is so much data on the C6 it seems.
When check further there are 0 in some spots that was bringing it down when I averaged the WOT 02 (I just averaged a bunch of spots when I saw 100% on the command throttle). It’s usually .86 to .87 taking out the 0 lines.
Also I am having a problem attaching my log to this post for anyone to look at.
Posted: Mon Aug 13, 2007 11:06 pm
you can email my your log if you want... lewis DOT eaton AT gmail DOT com
Posted: Tue Aug 14, 2007 8:32 am
by MikeBotz
Thanks, I just E-mailed the files
Posted: Tue Aug 14, 2007 9:31 am
by MikeBotz
The E-mail I sent was returned.
E-mail me if you can so I can reply with the file.
Posted: Tue Aug 14, 2007 12:40 pm
log was too big LOL excel wouldn't open up the whole 16MB csv file LOL
anyway, what I did get out of it is... your average ltft's are at +1.9xxx and +2.2xx
so I would start by adjusting your injector slope to -2%.
you also looked a little lean at WOT, so adjust both rpm ranges in the PE setting to be +2%.
sorry it took a while to get back to ya... I had 6 other people that sent me their logs too LOL
Posted: Tue Aug 14, 2007 1:02 pm
What a busy guy....hey Lew, when are we gonna set you up with CMR so you can start doing tunes????
Posted: Tue Aug 14, 2007 1:03 pm
that's what I wanna know??!!! where's that CMR software???
I could be your Northeast Satellite Office...
I know, I know... one thing at a time... k, so I'll take the tranny support FIRST, and THEN the CMR software...
Posted: Tue Aug 14, 2007 1:46 pm
by LostAngel
06MonteSS wrote:that's what I wanna know??!!! where's that CMR software???
Lew knows his stuff!
Posted: Tue Aug 14, 2007 4:26 pm
by Whiterock1
LostAngel wrote:06MonteSS wrote:that's what I wanna know??!!! where's that CMR software???
If you actually do start internet tuning, put me down...just have to walk me thru the data logging stuff.
Posted: Tue Aug 14, 2007 8:47 pm
by MikeBotz
Thanks for the reply. I tried to send you an excel file with 5 tabs, 10 minutes each to be under the 65,000 line max for each tab in excel 2003 but the E-mail was returned as file too big. In the 2007 version it opens all 229,000 lines of data. I d/l the demo version of office 2007.
I am going to change the tune and re log some data tomorrow hopefully.
Thanks again
Mike
Posted: Wed Aug 15, 2007 9:26 am
yeah, workin' on your log now... takin' a while... that's a lot of friggin' data for the macro's to go through line by line... LOL
be back to ya in a bit...
EDIT:
ok, well, I don't see any WOT runs in your log, so I can't help ya with any PE settings. Did you accidentally filter out the WOT data??
For your normal cruise/driving, your average ltft's were 3.64 and 2.71 - so, adjust the injector slope to be -2%.
Do another log, with a good WOT run in there, and let's see where stuff is at. You only need to log for about 20 minutes - that'll be enough data. And then send me the unfiltered log.
Thanks!
-Lew
Posted: Wed Aug 15, 2007 10:12 am
by MikeBotz
On my slow laptop i just ran it overnight for the o2, and it did take overnight. Then the next few days for the others, they went faster.
Posted: Wed Aug 15, 2007 10:17 am
by MikeBotz
I will do one later. how long should I hold the car at WOT while logging, 10 - 15 seconds at a time?
What would be better the .log, csv, or xml file?
Would it matter if I use datalogger 3.0, or 3.1 ? I saw that 3.1 had some issues sometimes when exporting the data.
Thanks, Mike
