Hi Guys , I installed a set of Ford camshaft and Comp Cams cam phaser limiter on a 2005 GT, since then I have those code P0011 , P0021 , I tried to cancelled the code but the customer is complaining that the car is a little bit tricky to run with out the variable camshaft , does somebody have an idea about that .
Mustang GT 2005 P0011, P0021 code
- julienperformance
RE: Mustang GT 2005 P0011, P0021 code
Did you set up the tune to get rid of VCT?
- julienperformance
No , when I'm cancelling it , the car is a little bit tricky to run at low speed .
Re: RE: Mustang GT 2005 P0011, P0021 code
Did you set up the tune to limit the cam angle? You need to for those limiters.julienperformance wrote:No , when I'm cancelling it , the car is a little bit tricky to run at low speed .
- julienperformance
RE: Re: RE: Mustang GT 2005 P0011, P0021 code
No , I will look at it .
