Mustang GT 2005 P0011, P0021 code
Posted: Thu Sep 15, 2011 9:49 am
by julienperformance
Hi Guys , I installed a set of Ford camshaft and Comp Cams cam phaser limiter on a 2005 GT, since then I have those code P0011 , P0021 , I tried to cancelled the code but the customer is complaining that the car is a little bit tricky to run with out the variable camshaft , does somebody have an idea about that .
RE: Mustang GT 2005 P0011, P0021 code
Posted: Thu Sep 15, 2011 10:23 am
by TKB
Did you set up the tune to get rid of VCT?
Posted: Tue Sep 20, 2011 9:55 am
No , when I'm cancelling it , the car is a little bit tricky to run at low speed .
Re: RE: Mustang GT 2005 P0011, P0021 code
Posted: Tue Sep 20, 2011 9:56 am
by TKB
julienperformance wrote:No , when I'm cancelling it , the car is a little bit tricky to run at low speed .
Did you set up the tune to limit the cam angle? You need to for those limiters.
RE: Re: RE: Mustang GT 2005 P0011, P0021 code
Posted: Tue Sep 20, 2011 4:17 pm
No , I will look at it .
