new predator user questions
Posted: Sun Aug 19, 2007 10:59 am
by njctd79
I just bought an 06 mustang GT. It came with a K&N CAI, BBK TB, underdrive pullies, BBK shorties, Flowmaster axle back and a Predator U7140 complete in the box.
I think the car has the provided Diablo performance tune in it but how can I tell.
I would like to experiment with small increases in the timing and shift firmness. Is this OK? Recommendations?
Would the car benefit from a custom tune now?
Kevin
Posted: Mon Aug 20, 2007 10:10 am
by ski
To determine which tune is currently loaded in the car's ECU, Select 'Options'/'Last Tune Written' in the Predator's menus.
It's not recommended to change the timing values, unless the engine is experiencing pinging, or you want to use gas with a higher octane than the tune, e.g., 93 octane gas with a 91 octane tune(increase global timing by 2 deg).
If you're referring to a dyno tune when you say 'custom tune', then that's always a good idea, since every engine is different. But obviously it will cost $.
Posted: Mon Aug 20, 2007 1:13 pm
by njctd79
Although a dyno tune is not out of the question I was referring to a tune emailed from a tuner like Bamachips built around the specs of the car.
Posted: Mon Aug 20, 2007 3:45 pm
by ski
Doug at Bamachips works with Predator tuners, so he can write a tune for your car.
Posted: Mon Aug 20, 2007 7:52 pm
by njctd79
Is email the only way to talk to Doug. I dont see a phone number on their website.
Posted: Mon Aug 20, 2007 11:36 pm
by bullitt1668
njctd79 wrote:Although a dyno tune is not out of the question I was referring to a tune emailed from a tuner like Bamachips built around the specs of the car.
How much some thing like this can cost?
All I have, engine performance, wise is 3.73 gears, off-road h-pipe, k&n cool air intake, and pulleys. And of course... the Predator (u7146).
2001 Kenny Brown Mustang Bullitt
Posted: Tue Aug 21, 2007 10:34 am
by ski
njctd79 wrote:Is email the only way to talk to Doug.
Yes
Posted: Tue Aug 21, 2007 10:35 am
by ski
I believe that Bamachips can do a tune for $75.
Posted: Tue Aug 21, 2007 7:11 pm
by bullitt1668
thanks!
Too bad we don't have anything like that around here!!!
Posted: Tue Aug 21, 2007 8:06 pm
by njctd79
[quote="ski"]To determine which tune is currently loaded in the car's ECU, Select 'Options'/'Last Tune Written' in the Predator's menus.
After determining which tune I had I changed it to the 91 octane tune and the car went into limp mode. I think it may be the aftermarket throttle body.
Posted: Tue Aug 21, 2007 11:22 pm
Yeah, aftermarket throttle bodies often cause this issue.
Try removing it and replacing it with the stocker, all should be fine.
Posted: Wed Aug 22, 2007 10:17 am
by njctd79
I put the stock TB on, put the 91 octane tune in and now the car kicks ass.
What can I do to tune for 93 octane.
Posted: Wed Aug 22, 2007 11:15 am
by ski
Advance the global timing by 2 deg.
Posted: Wed Aug 22, 2007 12:23 pm
by njctd79
How about shift firmness. My booklet shows it can be changed but I dont see it on the Predator menu. I noticed I have version 28 and there is a newer version on this site. Would that change be on the new version. I have the U7140 for an 06 stang auto.
