u7170 update
u7170 update
Hi Mike, I have a predator u7170 that is running 8r03. When I try liking with my trucks ecu I get the infamous vehicle not in database message with a call id of vnaa9s4. I know that you are updating this unit. Do you think it will be ready today. Thanks, any info would be great.
RE: u7170 update
Email sent.
dieseldoug
8r03?.......i tried the 8r01 with horrible results and was able to go back to the 7r19dz until a new update was developed. 19dz has a horrible flatspot in the throttle from 1/4 on in all tunes (manual trans).......8r01 was a joke........still waiting for a decent update........ready to bail ........maybe i should have chipped.........pretty sure that the ad for diablo didn't include" works good if you drive easy, but has a bad throttle surge.......but don't worry........we are working on it"........i appreciate everything diablo has done to make it better, but we are almost at strike 3 and still waiting for a decent update to fix the throttle surging.........
Not sure where mike is going with this but i just wanted to ask you is the CAL-ID you posted is from your truck {VNAA9S4} which i belive is not suported on the 8R01 but should be in the 8r03, however that CAL-ID is for a late 2000 AUTOMATIC truck not a manual and the 19DZ should work real good with this CAL-ID, if your tuck is MANUAL it should have a CAL -ID like VOAA8Q4 if is a
99-00 manual and the 19DZ those have a problem with either 60 or the 85hp with FLAT spot, lets make sure you have the correct CAL-ID in your truck, if you need more help you can e-mail me at [email protected] i know they are try to work all the bugs out so STAY TUNE for the update thanks
willie
DIABLOSPORT
DIABLOSPORT
dieseldoug
