Should I hook up the puck, or keep cruisin' RKL non stack?
Posted: Tue Aug 21, 2007 1:55 pm
by jmccart
Like it says. It seems like many guys install the puck and end up just cruising the programmer alone. What do you-all think?
RE: Should I hook up the puck, or keep cruisin
Posted: Tue Aug 21, 2007 2:11 pm
by Herculou
I'M NOT REALLY SURE WHAT THE PUCK DOES OTHER THAN RAISE THE FUEL PRESSURE. THE PROGRAMER IS MUCH BETTER, EXCEPT FOR THE FACT THAT IT CAN BE DETECTED............
Posted: Tue Aug 21, 2007 7:12 pm
by Dodgezilla
I have my Puck hooked up but I don't use it because I prefer the power on the non-stack tunes. The Puck also raises my rail pressure very high. It easily can go over 27000psi while the Predator alone doesn't go above 25000psi...
Posted: Tue Aug 21, 2007 11:09 pm
by madmanwithmouse
It's nice to be able to get a little boost when you need it. However I leave mine connected mainly because my quadzilla commander is connected to it.
Posted: Wed Aug 22, 2007 1:05 am
by bud8fan
im cruisin rkl stacked with the puck turned off...use it when i need it...
