2000 mustang gt / u7146 where do i start
00badstang
Post by 00badstang »
I have a 2000 mustang gt 5 speed with C&L 80mm mass air kit,C&L intake plenum ,BBK Roush 75 mm throttle body, Steeda pulleys, Magnaflow cat x-pipe, Magnaflow 15671 cat-back system , Ford racing 4:10 grear. Where do I start in the tune set up. I have no idea where to start, Thanks
RE: 2000 mustang gt / u7146 where do i start
Install the Diablo tune and modify it for the 4.10 gears and go from there.
00badstang
I was told that the Diablo tune from the factory would lean it out to much. Is that true ??
No.
00badstang
Does anyone else have any idea how I should set the parameters for the air or fuel? Thanks
00badstang
jdizzle
Post by jdizzle »
you shouldnot mess with air/fuel unless you have a wideband air/fuel guage. you should really have it dynoed if you wanna mess with that
jdizzle
Post by jdizzle »
with my mustang its a 00gt i only set the odbII to turn off the rear o2 sensors, advance timing all the way in the 2-4 k and 4-6k range and set the gears to 4.10. and that was all modified with the performance tune.
00badstang
Whats the difference between the Diablo tune , factory hp tune , and the tune original in the car? Thanks
Return to “Predator Ford Gas”
