2008 2500HD Duramax Diesel LMM
model # 7176
software revision on the Predator: Most recent as off 11/06/2011
I am going to be putting in a K&N cold air intake this week sometime and wasnt sure if I needed a custom tune to accept the k&n or can I run the stock tunes that came with my predator?
If I need to load any files just tell me which ones I need to load 120hp or what not?
thanks in advance.
Do I need a custom tune?
RE: Do I need a custom tune?
No need for a custom tune, load the tune and go
fastmatt007
Re: RE: Do I need a custom tune?
Tune is already loaded, but do I need another tune when I install the K&N? I had another predator for my 06 mustang and it had a tune I could select, firm shift k&N option or just a K&N. Just wanted to make sure I would get a error when I put the cold air intake in bc its on ac ustom tune and I am adding a aftermarket k&N intake again.mikel wrote:No need for a custom tune, load the tune and go
RE: Re: RE: Do I need a custom tune?
no need to change anything
fastmatt007
diesels dont require custom tunes till you go nuts with turbo kits or big injectors
