Page 1 of 3
2011 EXT TCM-Shiftfirmness not working?
Posted: Sun Jan 08, 2012 11:05 am
by 48548
I spoke to Lew after he fixed the hard lanching issue with WOT, thanks Lew. It seems like I have never been able to change the shift firmness in a way that I can actually feel the change. I have tried firm and now currently HARD options and doesn't seem to change anything. Here are the two crom files I have used and the last one is the one current on my trinity.
trinity_gm_can_gas-1r08h_update
trinity_gm_can_gas_1t08hl_update_786
Maybe there is a bug or I am smoking something or both
RE: 2011 EXT TCM-Shiftfirmness not working?
Posted: Mon Jan 09, 2012 11:44 am
after you installed that new crom revision update, you then reselected your vehicle/engine right?
go to options / show information and what does it show for the version/revision it's on?
Posted: Mon Jan 09, 2012 12:38 pm
by 48548
I will check tonight. Yes I did reselect my vehicle. I am pretty sure when I did check it was the last file I posted above. The 1t08hl. But I will check again tonight to confirm it.
Posted: Mon Jan 09, 2012 2:13 pm
by Avantgarde
It never worked for me either, 48548!
Posted: Mon Jan 09, 2012 2:56 pm
by 48548
I feel better, I thought it was something I did.
Posted: Mon Jan 09, 2012 3:41 pm
All on 1t08hl?
Posted: Mon Jan 09, 2012 3:56 pm
by 48548
Either of the two above from what I can tell.
Posted: Tue Jan 10, 2012 10:42 am
by 48548
Either two of the above I have seem to think it doesn't have any effect on the shift firmness. But the programer has the 1t08hl in it right now.
Posted: Mon Jan 30, 2012 6:16 pm
by 48548
I just updated the tool yesterday, and still doesn't do anything no matter which option I pick, hard or firm or stock shifting. It always shifts the same.
Posted: Mon Jan 30, 2012 6:28 pm
please load the tunes then export a copy of the stock tune and last tune written and post them here.
Posted: Mon Jan 30, 2012 9:48 pm
by 48548
Here are the files....
The original are obvious.... the caddy_1 file I got from lew to fix the hard lurching from 1st to second and save my tranny!!!! and other are the last tunes written...
Posted: Wed Feb 01, 2012 3:09 pm
by 48548
Were these the files you were looking for?
Posted: Wed Feb 01, 2012 3:24 pm
yes, we'll check it out.
Posted: Wed Feb 01, 2012 10:16 pm
by johan
See how you like the attached trans tune here, let us know.
Posted: Thu Feb 02, 2012 10:42 am
by 48548
I will try it. The question is why didn't any of the options change the shifting firmness? I like to be able to change them when I want to. I wasn't sure if there is something wrong with my tranny or TCM... I assume everyone else can change their tranny options and they work, so I figured it was an issue with my vehicle/tranny. Any special way to use the tune above, I have only used an engine tune, not a tranny tune. And if I think it shift to hard what options do I have? Also I wanted to leave on my TM on 100 percent as I have a heavy truck. I want firm shifts but don't want to risk the tranny life by removing TM.
