i've had this thing for 1 day and already hate it to death.
sebby
Post by sebby »
this thing is extremely buggy...........
1) plugged it into computer - wont install driver cause im not logged in as an admin... but im logged in as an admin
2) wont let me register because i need a code, wont email me a code, tried with 4 different emails with 4 different email providers
3) plugged into car, asked for 89 octane with tire size change, froze in tire size change.. so had to install 89 without tire size change
4) tried restoring vehicle to try on my other car, restores backup just fine... but gets frozen on restoring tire size........that i was never able to change in the first place....
5) why do i have to call diablosport to force original backup??!?! i dont want to pay long distance, i dont want to wait till monday.
so im stuck with this thing tuned on my car with no possible way of restoring my original backup till monday, when im at work and dont have the time to call.......
please without having to leave work early in order to call you guys, help me uninstall this POS from my car...
JonDiablosport
RE: i
Post by JonDiablosport »
We have a update avialable that will fix most of your issues.
registration is not required for use.
if you click on the icon by the clock. open the program that looks like an intune go to explore. then cdrom a file will open up. the intune .exe right click it then hit run as admin. and you will be good on the driver as well. if the icon is not near your clock then find it in my computer section.
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
sebby
RE: i
Post by sebby »
where do i get the update because when i use the application it came with, it says this intune is up to date.
RE: i
sebby
RE: i
Post by sebby »
that update actually made it worse...... it freezes on almost every screen and always say no ecu found check key or check cable.....this thing sucks
JonDiablosport
RE: i
in the settings, tool info, firmware info screen what is your application version?
p: 561-908-0040
F: 561-908-0048
sebby
RE: i
Post by sebby »
1t01db
YD-LUZ
RE: i
Post by YD-LUZ »
sebby, I am a new user of the InTune myself. Had a few questions and issues right out of the gate. But, with a little time figured things out and now, I could not be any happier. My advice, relax and let 'em help you, chaulk it up as all part of the experience. I've built many nationally featured cars on not a one of them went together without some curve balls.
Good Luck!
Richmonddjs
RE: i
Post by Richmonddjs »
Latest version is 1r01d. You need to update.
sebby
RE: i
Post by sebby »
i've updated it and its still exactly the same if not worse, i still cannot restore my original tune it gets stuck all the time on restoring tire size. and it just randomly freezes here and there, trying to use it as an obd scanner, it cant read any car it says no ecu found
RE: i
please give us a call Mon-Fri - 9am-6pm, with it in the vehicle so we can try to help you out.
