Wil mafia work for my application
Posted: Mon Jan 16, 2012 11:52 pm
Its a little different than what you guys are used to but id like to see if this would work.
Its a nissan 240sx engine is a infinity q45 v8 with a vortech supercharger running a modified (live tunable) ecu with stock maf in a blow through application.
The stock maf is a hot wire maf that reads 0-5.114 volts and is pegged right now at 5.114 volts (max reading for the ecu) right before redline 6500 rpm (redline 7000). It is making 436 whp at 8 psi.
I need to extend this as i want to go up in boost to 10-12 psi and need some more range.
Will mafia work in this application.
Here is a picture of the setup
