Page 1 of 2
Data Viewer Question
Posted: Mon Sep 24, 2007 11:21 am
by jimmybuckets
Can the Data View be used to log 0-60 and other performance type parameters?
RE: Data Viewer Question
Posted: Mon Sep 24, 2007 11:26 am
nope, no performance parameters (like a g-tech) are available...
Posted: Tue Sep 25, 2007 9:22 am
by jimmybuckets
Is the reason they can't do it because they don't have TCM support yet?
Posted: Tue Sep 25, 2007 10:01 am
don't know / not sure....
Posted: Tue Sep 25, 2007 11:30 am
No, it has nothing at all to do with TCM support.
The hardware in the Predator will not support that.
Posted: Tue Sep 25, 2007 5:23 pm
by jsk06c6
Would be easy to figure out from the log. It records speed versus time after all. You could also calculate quarter mile times as a function of speed versus time as well.
Diablo could easily add this functionality to the DataView if they wanted.
Once I get the unit, suppose to arrive thursday, I'll check out the dataview a little more. If we can export into an excel spreadsheet it should be rather easy to make a macro to do the calculations. I'll let you know.
Posted: Tue Sep 25, 2007 10:40 pm
cool, more macros!!!! a guy after my own heart!!
Posted: Wed Sep 26, 2007 11:19 am
by jimmybuckets
I don't know how to do it...but I was thinking along the same lines...all the info is there to figure it out
Posted: Fri Sep 28, 2007 7:59 am
by jimmybuckets
Actually you can log vehicle speed and time is being logged already...is it that simple with the data viewer?
Posted: Fri Sep 28, 2007 3:27 pm
by FastBlueSS
How much longer till TCM support?
Posted: Fri Sep 28, 2007 5:34 pm
by jimmybuckets
Ha TCM...any whoo...I logged some 0-60 vs time loggs with the Data view...gives me a best run of 8.1 seconds...a little worse than what superchips flashpaq was telling me I was getting...is this a viable way of getting these times?
Posted: Fri Sep 28, 2007 10:42 pm
not really.. cuz it only takes data snapshots every so often... every certain amount of seconds... so more than likely you were faster than that, but by the time the next data-record cycle came around to record that time interval, you were already past it
Posted: Fri Sep 28, 2007 11:11 pm
by jimmybuckets
I'm sure sample rate has something to do with it...my only question is that there were around 650 samples in that time span from 0-60...seems like it should be pretty close...just poking around here a little
Posted: Fri Sep 28, 2007 11:20 pm
by jsk06c6
jimmybuckets wrote:I'm sure sample rate has something to do with it...my only question is that there were around 650 samples in that time span from 0-60...seems like it should be pretty close...just poking around here a little
It is. It's showing me at about 4.2 seconds 0-60. Thats about right for the conditions. Just hang jimmy, I'm working on the macros. But, I'm showing 6 thousands of a second between data writes in a log. Perhaps thats the problem the 7194's are having, we are grabbing data too fast. If they were to slow it down, the device isn't really going to able to give us the data fast enough to do these calculations. I'd rather it stay the way it is than increase the interval between data logs to increase the log time.
Best of both worlds would be to be able to select the data log interval.
Worse case, its a much better device as is, than what the others are. So I wont be upgrading it if it loses this functionality.
Posted: Fri Sep 28, 2007 11:28 pm
sweet!! somebody else doing macros!!! WOOHOO!!!
