SRT-4 Halt Monitering Issue!!!! please help
bstock1990
Post by bstock1990 »
Hello I have a problem with my trinity and its becoming more frequent and very annoying ..
When Im driving and just "Monitoring" my PIDS I keep on getting the "Halt Monitoring Screen" it happens every 15 to 45 minutes I have to unplug it and restart it every time ..
Serial :6JXY6B2-1
Version:1r08c
RE: SRT-4 Halt Monitering Issue!!!! please help
analog inputs? how many pids?
bstock1990
Re: RE: SRT-4 Halt Monitering Issue!!!! please help
mikel wrote:analog inputs? how many pids?
Yes wideband for analog..
And 2 PID per page with a total of 4 pages..
Most common pid is AFR with boost or AFR with STKnock
nemiro
RE: Re: RE: SRT-4 Halt Monitering Issue!!!! please help
Post by nemiro »
This is the same issue discussed many times on SRTForums.
__________________________
Neil Emiro - ND Performance
http://www.ndperformance.com
there is some rhyme or reason to certainpids aiding in this issue.
I tested it for days and was unable to reproduce it, then Duster gave me a layout he uses, I loaded it, and was able to get the issue almost immediately.
it is on the list of things to get fixed here for sure.
nemiro
Post by nemiro »
I can reproduce it with any selection of PIDs. What seems to vary is how much ignition off time is required to make it happen. Never seems to be more than 10 minutes, though, and times of less than 5 minutes often makes it not happen at all. Also, the Trinity will do this right in the middle of a logged run, and it often seems to happen during the first high RPM/high load event of the log. Instead of a HALT MONITORING message, you will get a 'Save Recorded Data? Yes/No' message.
bstock1990
I changed my layout seems to be doing it less ..at first I had 2 medium digital guages per page it was happening every 5 minutes now iam doing the same but adding a small digital and its doing less frequently,.
I wonder if certain layouts/backrounds/PIDS is causing the issue?
bstock1990
Re: RE: Re: RE: SRT-4 Halt Monitering Issue!!!! please help
mikel wrote:there is some rhyme or reason to certainpids aiding in this issue.
it is on the list of to get fixed here for sure.
The list of things of things ??what does that meen?? So basically it hasnt been a big enough issue for you guys to fix?
It seems to me that you guys are more worried about putting out new products and making money instead of repairing a product that has a problem and is causing alot of unhappy customers!!
Obviously this issue is been going on for a while..
You guys should get going on your list
nemiro
RE: Re: RE: Re: RE: SRT-4 Halt Monitering Issue!!!! please
Post by nemiro »
I'll upload some layouts that definitely give issues this week.
gizmodo
Post by gizmodo »
I reported this back in April of 2011 when the last update came out...
nemiro
Post by nemiro »
Believe that Mike indicated at one point that things got 'broken' on this last update. Almost a year on, it would be nice to get this fixed once and for all!
nemiro
Post by nemiro »
Layout attached. This one works well for what I need, but will lock the DST up every time.
SRT_TUNING_SPARK.TDS
Layout that locks up the Trinity like clockwork - but does what I need it to do.
(658 Bytes) Downloaded 204 times
nemiro
Post by nemiro »
(658 Bytes) Downloaded 196 times
nemiro
Post by nemiro »
Anything more on this? I have some software feature requests for Trinity that I think would be both straightforward to implement and would really enhance the product, but I don't even want to go there until this bug, introduced on one of the last updates, is tackled.
nemiro
Post by nemiro »
Know you guys are busy working on Ford inTune, but would be great if we could revisit this. This issue cropped up at the 1R08 update, so it would seem finding the issue would not be that terribly difficult or time consuming. There is a thread on srtforums.com that this issue is being discussed right now, and the potential is an explosive backlash. As one of you dealers, I don't want this to impact myself or DS. Please at least engage the conversation.
