intune stuck in recovery mode
UnseenByYou
has anyone else has this issue and how do you fix it? its seriously starting to piss me off. when i say continue when it says its still in recovery mode it proceeds to say "the last tune failed to install, the original backup will now be restored to the vehicle". i then click the green check mark and it acts like its going to load and then it says "an error occurred while restoring Original Backup".....WTF is going on here? thanks! only thing ive done to the car since was install a slim battery, but that wouldnt mess anything up, would it? car still starts up and runs fine.
after tryin again to load the original back up, the intune acts like its gonna load it but then it restarts itself
UnseenByYou
RE: intune stuck in recovery mode
i can provide video if its needed as well
BlackZ71Silverado
Is EVERYTHING that did not come in the vehicle from the factory disconnected, fuse pulled?
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
what vehicle?
what happened?
were you able to load a tune?
dies the vehicle start?
please give us a call with the tool powered up inthe vehicle so we can try to help.
what happened?
UnseenByYou
Re: RE: intune stuck in recovery mode
only thing not factory right now is the head unitBlackZ71Silverado wrote:Is EVERYTHING that did not come in the vehicle from the factory disconnected, fuse pulled?
UnseenByYou
1. 2005 dodge neon srt 4mikel wrote:what vehicle?
what happened?
2. i went to adjust the tune because i had KR and it wouldnt load the tune, then it proceeding to get stuck in recovery mode
3. no
4. yes it starts
5. i called the other day, got the password to reset the tuner, got a update from online as i was told, reconnected it back to the car and it went straight back into recovery mode. i will be calling again today to hopefully figure out a solution.
jharman1982
RE: Re: RE: intune stuck in recovery mode
This same thing is happening to my vehicle. I have an 07 yukon denali xl, 6.2, gas. It too is stuck in recovery mode and cant load original tune to vehicle. It fails to install every time. MY vehicle wont even start and had to leave it at work. BTW been on hold wed. morning for 1 hour now. I have had the intune for a couple of months with no major problems until now. This all happened simply because i was trying to change tunes for a diablo tune to a mpg booster tune due to rising gas prices!!! Please help I need my vehicle.
we'll get you sorted out on the phone, sorry about that.UnseenByYou wrote:1. 2005 dodge neon srt 4mikel wrote:what vehicle?
what happened?
3. no
4. yes it starts
Re: RE: Re: RE: intune stuck in recovery mode
I believe we just spoke, let us know when you have the tool in the vehicle and we'll get it going.jharman1982 wrote:This same thing is happening to my vehicle. I have an 07 yukon denali xl, 6.2, gas. It too is stuck in recovery mode and cant load original tune to vehicle. It fails to install every time. MY vehicle wont even start and had to leave it at work. BTW been on hold wed. morning for 1 hour now. I have had the intune for a couple of months with no major problems until now. This all happened simply because i was trying to change tunes for a diablo tune to a mpg booster tune due to rising gas prices!!! Please help I need my vehicle.
Re: intune stuck in recovery mode
HI,
My intone is stuck in recovery mode after it failed to restore original backup. I was unable to register because the internet went out. Please help my 2014 dodge ram w/electronic shift will not start
k5chevyblazer
2011 Silverado 1500
Same problem. Cannot load original back up file. Upload gets to 93% and it crashes. Truck stuck in a limp mode. It will start and stay running but it will only drive in what seems like 3rd gear.
Colin_11208
Mines doing the exact same thing I neee help I'm starting to get worried
