2011 camaro rear axel ratio help
Posted: Wed Feb 29, 2012 9:43 pm
by IC1Patton
I'm looking to change my rear end gears to 4.10 and i tried setting that on my trinity but it will not let me select the new gears. it will let me set it to 0 1 5 or 6 thats it.
RE: 2011 camaro rear axel ratio help
Posted: Thu Mar 01, 2012 11:57 am
hmm...there should be a fine and coarse adjustment, try the fine (single arrow) adjustment and see if it lets you change it to what you need.
Posted: Thu Mar 01, 2012 7:15 pm
by IC1Patton
i tried that and i got the same issue both the fine and course are selecting the same numbers
Posted: Thu Mar 01, 2012 7:28 pm
latest revision?
Posted: Thu Mar 01, 2012 9:07 pm
by IC1Patton
its 1r08k
Posted: Fri Mar 02, 2012 10:17 am
post up the last tune written and the backup for now and we'll make you a custom tune to fix it.
Posted: Sun Mar 04, 2012 11:40 am
by IC1Patton
here is one i am running if i make future mods and need to get a custom tune will it revert back
Posted: Sun Mar 04, 2012 12:58 pm
by Mike_Levy
Thats not what Mike wants. He's gonna make you a custom tune. Export the Last Tune Written off the Trinity and post that.
Posted: Sun Mar 04, 2012 7:48 pm
by 06MonteSS
yeah... that's the data logging gauge layout file... you need to use the dsdownloader software and Get Tune File From Tool... and get the original backup tune file, and then do it again and get the last tune written tune file... then post them up here...
Re: 2011 camaro rear axel ratio help
Posted: Mon Mar 05, 2012 1:38 am
by rlkimmel
IC1Patton wrote:I'm looking to change my rear end gears to 4.10 and i tried setting that on my trinity but it will not let me select the new gears. it will let me set it to 0 1 5 or 6 thats it.
I have a suggestion that will work. First, you will need a gps to give you an accurate speed. Select whatever ratio is closest to what you want. GM uses a 41 tooth ring gear and just changes the pinion. (4.10 = 10 tooth - 3.73 = 11 tooth - 3.42 = 12 tooth) They have been doing the same thing on their light trucks and performance cars with rear wheel drive since the 60's. (Anyone remember the 12 bolt posi's?) Then select a smaller diameter tire than what your really using until your speedometer registers the same speed as the gps and then you have it. It really doesn't make much difference what numbers you use to get the correct speedo reading. What matters is drive shaft revolutions per tire revolution.
Posted: Mon Mar 05, 2012 4:10 pm
by IC1Patton
heres the back up
Posted: Mon Mar 05, 2012 4:11 pm
by IC1Patton
here is the last tune written
Posted: Mon Mar 05, 2012 4:44 pm
by 06MonteSS
here ya go man....
Posted: Mon Mar 05, 2012 4:45 pm
by 06MonteSS
make sure you RESET ALL PARAMETERS when you select this tune to install it... because all the other changes you made yourself before are already in this custom tune file...
Posted: Mon Mar 05, 2012 6:45 pm
by IC1Patton
thanks alot and thank you for the quick responses
