2011 camaro rear axel ratio help
IC1Patton
Post by IC1Patton »
I'm looking to change my rear end gears to 4.10 and i tried setting that on my trinity but it will not let me select the new gears. it will let me set it to 0 1 5 or 6 thats it.
RE: 2011 camaro rear axel ratio help
hmm...there should be a fine and coarse adjustment, try the fine (single arrow) adjustment and see if it lets you change it to what you need.
IC1Patton
Post by IC1Patton »
i tried that and i got the same issue both the fine and course are selecting the same numbers
latest revision?
IC1Patton
Post by IC1Patton »
its 1r08k
post up the last tune written and the backup for now and we'll make you a custom tune to fix it.
IC1Patton
Post by IC1Patton »
here is one i am running if i make future mods and need to get a custom tune will it revert back
GM_GAS.TDS
(1.11 KiB) Downloaded 232 times
Thats not what Mike wants. He's gonna make you a custom tune. Export the Last Tune Written off the Trinity and post that.
yeah... that's the data logging gauge layout file... you need to use the dsdownloader software and Get Tune File From Tool... and get the original backup tune file, and then do it again and get the last tune written tune file... then post them up here...
rlkimmel
Re: 2011 camaro rear axel ratio help
Post by rlkimmel »
IC1Patton wrote:I'm looking to change my rear end gears to 4.10 and i tried setting that on my trinity but it will not let me select the new gears. it will let me set it to 0 1 5 or 6 thats it.
I have a suggestion that will work. First, you will need a gps to give you an accurate speed. Select whatever ratio is closest to what you want. GM uses a 41 tooth ring gear and just changes the pinion. (4.10 = 10 tooth - 3.73 = 11 tooth - 3.42 = 12 tooth) They have been doing the same thing on their light trucks and performance cars with rear wheel drive since the 60's. (Anyone remember the 12 bolt posi's?) Then select a smaller diameter tire than what your really using until your speedometer registers the same speed as the gps and then you have it. It really doesn't make much difference what numbers you use to get the correct speedo reading. What matters is drive shaft revolutions per tire revolution.
IC1Patton
Post by IC1Patton »
heres the back up
back up.grg
(62.95 KiB) Downloaded 256 times
IC1Patton
Post by IC1Patton »
here is the last tune written
PCM_639270642189_91_Octane_Tune_modified.grg
(4.25 KiB) Downloaded 331 times
here ya go man....
pcm_639270642189_91_octane_tune_410gears.grg
(54.27 KiB) Downloaded 243 times
make sure you RESET ALL PARAMETERS when you select this tune to install it... because all the other changes you made yourself before are already in this custom tune file...
IC1Patton
Post by IC1Patton »
thanks alot and thank you for the quick responses
Return to “Trinity GM Gas”
