2011 camaro rear axel ratio help
I'm looking to change my rear end gears to 4.10 and i tried setting that on my trinity but it will not let me select the new gears. it will let me set it to 0 1 5 or 6 thats it.
RE: 2011 camaro rear axel ratio help
hmm...there should be a fine and coarse adjustment, try the fine (single arrow) adjustment and see if it lets you change it to what you need.
i tried that and i got the same issue both the fine and course are selecting the same numbers
latest revision?
its 1r08k
post up the last tune written and the backup for now and we'll make you a custom tune to fix it.
here is one i am running if i make future mods and need to get a custom tune will it revert back
- GM_GAS.TDS
- (1.11 KiB) Downloaded 232 times
yeah... that's the data logging gauge layout file... you need to use the dsdownloader software and Get Tune File From Tool... and get the original backup tune file, and then do it again and get the last tune written tune file... then post them up here...
Re: 2011 camaro rear axel ratio help
IC1Patton wrote:I'm looking to change my rear end gears to 4.10 and i tried setting that on my trinity but it will not let me select the new gears. it will let me set it to 0 1 5 or 6 thats it.
I have a suggestion that will work. First, you will need a gps to give you an accurate speed. Select whatever ratio is closest to what you want. GM uses a 41 tooth ring gear and just changes the pinion. (4.10 = 10 tooth - 3.73 = 11 tooth - 3.42 = 12 tooth) They have been doing the same thing on their light trucks and performance cars with rear wheel drive since the 60's. (Anyone remember the 12 bolt posi's?) Then select a smaller diameter tire than what your really using until your speedometer registers the same speed as the gps and then you have it. It really doesn't make much difference what numbers you use to get the correct speedo reading. What matters is drive shaft revolutions per tire revolution.
here is the last tune written
- PCM_639270642189_91_Octane_Tune_modified.grg
- (4.25 KiB) Downloaded 331 times
here ya go man....
- pcm_639270642189_91_octane_tune_410gears.grg
- (54.27 KiB) Downloaded 243 times
make sure you RESET ALL PARAMETERS when you select this tune to install it... because all the other changes you made yourself before are already in this custom tune file...
