Datalogging software
mistercrow
Post by mistercrow »
Where do I download it at?
RE: Datalogging software
mistercrow
Thanks!
mistercrow
Guess I gotta be plugged into the truck for this to work? Just tried to view a log and caught an error....
mistercrow
Re: RE: Datalogging software
mistercrow wrote:Guess I gotta be plugged into the truck for this to work? Just tried to view a log and caught an error....
NM, evidently this is another InTune error I guess...moderators????? log file was an invalid format....?????
gizmodo
RE: Re: RE: Datalogging software
Post by gizmodo »
What is the error? The inTune doesn't need to be plugged into the truck. Just drag the log file off the inTune onto your computer and open it with DataViewer.
mistercrow
I either get 'command not supported' or 'invalid format'
rdss
Post by rdss »
Are you trying to run a log on the InTune or on the computer? Like gizmodo said, pull the log off the InTune so that the software is running the log file off the computer and not having to read the data off of the InTune.
2010 GMC Sierra 5.3
K&N Aircharger
mistercrow
On the comp. I got it now, using the icons to bring it to the DV threw errors so I tried the good ole drag and drop method and it worked.
rdss
Post by rdss »
I cant remember if it worked directly off the InTune pumped to the DV, not sure I even tried. I just figured it would run smoother off the computers HD. Glad you got it to work.
2010 GMC Sierra 5.3
K&N Aircharger
mistercrow
It works sometimes...like right now the Intune is plugged into the computer and powered up but after 20 minutes the DV still hasnt found it...
driver installed?
mistercrow
Yeah, its all installed...the DV is just pissy about finding it sometimes.
