Ok, that's not entirely fair to say because some days it works completely fine and then other days it won't turn on at all. My cruise control was 100% fine before installing the intune.
My Jeep is a 2005 Grand Cherokee 5.7L. From reading Jeepforum.com, it appears I'm not the only jeep owner that has had this problem.
Cruise Control Doesn't work
RE: Cruise Control Doesn
we are looking into this.
blizzboy283
Re: RE: Cruise Control Doesn
It seems to be a little better now but it still doesn't want to work at all some days. Before it use to almost rotate days that it would work and now it might work for 2 or 3 days and then not work.mikel wrote:we are looking into this.
- fireman2118
RE: Re: RE: Cruise Control Doesn
Pull the fuse to the PCM for 30 seconds, see if that helps. I had the same issue with my '05 Magnum back when I first tuned it.
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
