2004.5 5.9 trinity problem
Post your Cummins related Trinity questions here.
camoboy
Post by camoboy »
2004.5 ram 2500 5.9 cummins auto tranny. i just did the update for my tool and was hoping that it would solve the problem but i guess not. when i go to create a custom gauge layout i can put all the gauges on there but when i set the parameters it only gives me the analog input menu. i cant set parameters for anything else. anyone have this problem or know of a fix?
also is it normal for the tunes to take about 15 minutes to load on these trucks? and my extreme tune wont even load
RE: 2004.5 5.9 trinity problem
these trucks take a log time to flash, yes.
Are you saying that you cannot select any PIDs to create new layouts?
camoboy
Post by camoboy »
ok thanks and yes i dont have any regular PIDs at all. i only have the analog input menu for PIDs
are you sure you have the correct application selected?
options/tool info, what is part number?
camoboy
Post by camoboy »
Yes I'm sure. Part #u7130 cummins version v. 1r08b
Also when I goin to monitoring while the truck is running all the gauges on the Diablo will be at zero and I have to back out and go back in it and then it will work fine
I will test this on the bench as soon as I get a chance...
camoboy
Post by camoboy »
Ok thanks just let me know
camoboy
Post by camoboy »
camoboy
Post by camoboy »
anything yet on this?
camoboy
Post by camoboy »
now the trinity will not load the extreme tune at all. i let it sit for 30 minutes and it didnt even get off 0%. i unplugged the tool and i reloaded the stock tune then loaded the performance tune and it started to load right away. whats goin on? im thinkin about selling this for somethin else.....
try disconnecting the batteries for a minute or two then see if it flashes OK.
Return to “Trinity Dodge Diesel”
