2004.5 5.9 trinity problem
Posted: Tue Apr 10, 2012 10:30 pm
by camoboy
2004.5 ram 2500 5.9 cummins auto tranny. i just did the update for my tool and was hoping that it would solve the problem but i guess not. when i go to create a custom gauge layout i can put all the gauges on there but when i set the parameters it only gives me the analog input menu. i cant set parameters for anything else. anyone have this problem or know of a fix?
also is it normal for the tunes to take about 15 minutes to load on these trucks? and my extreme tune wont even load
RE: 2004.5 5.9 trinity problem
Posted: Wed Apr 11, 2012 12:52 pm
these trucks take a log time to flash, yes.
Are you saying that you cannot select any PIDs to create new layouts?
Posted: Wed Apr 11, 2012 10:07 pm
by camoboy
ok thanks and yes i dont have any regular PIDs at all. i only have the analog input menu for PIDs
Posted: Thu Apr 12, 2012 11:31 am
are you sure you have the correct application selected?
options/tool info, what is part number?
Posted: Fri Apr 13, 2012 7:50 am
by camoboy
Yes I'm sure. Part #u7130 cummins version v. 1r08b
Also when I goin to monitoring while the truck is running all the gauges on the Diablo will be at zero and I have to back out and go back in it and then it will work fine
Posted: Fri Apr 13, 2012 9:04 am
I will test this on the bench as soon as I get a chance...
Posted: Fri Apr 13, 2012 2:08 pm
by camoboy
Ok thanks just let me know
by camoboy
Posted: Sun Apr 29, 2012 6:52 pm
by camoboy
anything yet on this?
Posted: Wed May 02, 2012 10:22 pm
by camoboy
now the trinity will not load the extreme tune at all. i let it sit for 30 minutes and it didnt even get off 0%. i unplugged the tool and i reloaded the stock tune then loaded the performance tune and it started to load right away. whats goin on? im thinkin about selling this for somethin else.....
Posted: Thu May 03, 2012 11:58 am
try disconnecting the batteries for a minute or two then see if it flashes OK.
