What should I enter for fan temp settings
Posted: Fri Oct 19, 2007 9:39 pm
by ayeaye
does anyone know the stock fan settings on the 06 Charger SRT8?
I entered
180 for LS fan
205 for MS fan
220 for HS fan
I am on CAI perf 91 oct setting stock tstat
fan
Posted: Fri Oct 19, 2007 9:53 pm
by guidosrt8
that sounds right for stock stat if you do a 180 i would use 180-190-205
Posted: Sat Oct 20, 2007 1:26 am
by k9289
Mike question:
07 R/T 5.7
Are these good settings with just a CAI, 180 Stat and Catback? Using 93+CAI tune
180 LS
190 MS
205 HS
Posted: Sat Oct 20, 2007 4:54 am
by ayeaye
thanks guiodosrt
Posted: Sun Oct 21, 2007 9:00 pm
by copracer288
The fan settings are already adjusted for a 180 stat in the canned tune.
Turning on the LS fan at 180 might cause it to run too much.
When cruising on the highway I run between 183 - 185 with the 180 stat. The canned tune has the LS fan coming on at 190.
Posted: Sat Oct 27, 2007 11:55 pm
by Scottwoos06RT
Hmm...
Got mine set to 184, 187 and 192.... no idea if it's right or not, but car is staying cool and the fans are cycling
Posted: Sun Oct 28, 2007 3:33 am
by Mike_Levy
I have mine set on whatever it came with, but the fans are running constantly. Really annoying. Whats the highest temp that can be used to turn them on?
Posted: Mon Oct 29, 2007 9:44 am
by christina
If you would like to set it to stock settings, you can go into Modify Stock Tune and it will show you what it is at stock.
Posted: Mon Oct 29, 2007 2:58 pm
by BUZ-CCC
christina wrote:If you would like to set it to stock settings, you can go into Modify Stock Tune and it will show you what it is at stock.
If Diablo set fan for 180 stat at 190 low 199 high I would think you could set fans at 213 low 222 high as stock stat is 203degrees this would give you the same spread that they used. Stock settings are real high 219 low 226 high.
