Alright, I did the official update today. To make sure I wouldn't get screwed, I reflashed the original back up on the PCM before doing the update. Yeah...Still got screwed.
Now after the update, the Intune won't let me access the custom tunes section. I assume it's because it thinks that they don't match with the current original backup. I even tried coping over the 1st original backup I did with no success. The latest backup the Intune took is slightly larger then the original so it must be different. I need this fixed ASAP because I run on E85 with big injectors.
Keep in mind that my car is a 2004 SRT-4 with a Mopar Stage 3 PCM. See attached my original backup (the one the tune was made for), the latest backup (the last one the Intune took and the custom tune I'm trying to flash).
P.S. Since I 1st got the Intune, custom tunes that I would put in the tune folder would disappear. I could select them in the car but couldn't see them on a PC. Is that a normal behavior?
InTune HELP! Won't recognise custon tune after update
RE: InTune HELP! Won
I emailed my files to support at DS and within an hour I was able to load my custom tune again. I sent in all the files like shown above and they knocked it out. I did include my intune serial number as well
LGSONE
LGSONE
Ok, I sent 2 emails. I really need my car tonight.
My intune is fucked. I didn't notice it at 1st but even after restoring the original backup the 'restore vehicle' button stays enabled. Like it didn't actually restore the backup. But if I select in once more it says that there's no backup file for 'xxx' (even if I recopy my proper 1st original backup).
I will be calling you guys tomorrow for a forced calibration.
