We just completed installing a new Comp Cam 274 For the VVT 5.7 Hemi.
It starts but will not hold an idle under 800 RPM.
We need to be able to change the Fuel Tables and Set the Cam Phaser Tables to limit timing to not exceed 14 Degrees.
Is there a way to use my INTUNE to make the adjustments?
Can I send you a data log and have a custom tune Made?
Let me Know.
Brian
I-1000
2010, Dodge, Challenger R/T 5.7 6 Speed
5.7 2010 Challenger W Comp Cam 274VVT Cam installed
Challengeit
RE: 5.7 2010 Challenger W Comp Cam 274VVT Cam installed
No, you need to contact a CMR tuner to help...
Challengeit
Ok, I was pretty sure that would be the answer.
Thanks for the quick response!!
Brian
Brian
Why Is It So Much Fun Getting to the next Red Light Before the next Guy???!!!
Challengeit
Re: 5.7 2010 Challenger W Comp Cam 274VVT Cam installed
Mike,
Just Updating you, that we have a Realy great Tune now on ChallengeIT!!
STS Turbo in Utah did the work.
Brian
Brian
good deal, Rick is the man
Challengeit
Yes He Is!
Thanks for your support as well.
Brian
Brian
