Transmission adaptation reset failed................WHY?
Posted: Mon Jun 18, 2012 11:32 am
by fireman2118
I've been running a custom CMR tune in my 2005 Magnum for quite some time now. I updated my Intune and had no problems with making tune adjustments. The transmission reset adaptives was working fine.
Now, for some reason, when I hook up the Intune, the transmission adaptation reset fails. It will not work. Everything else seems to work fine.
I have an '05 Magnum with a standard TCM. The TCM was replaced in 2007
Calid 04896415AK
RE: Transmission adaptation reset failed................WHY?
Posted: Mon Jun 18, 2012 12:21 pm
we're working on that.
Posted: Wed Jun 27, 2012 11:09 am
by fireman2118
Any update on this?
RE: The Riviera Resort Durgapur
Posted: Fri Jun 29, 2012 8:57 pm
by fireman2118
F'n spammers!
Any update on the transmission adaptives reset issue?
Posted: Tue Jul 10, 2012 9:48 am
by fireman2118
Is there any progress with the transmission adaptives reset "failed" issue?
It's been 3 weeks!
Posted: Sun Jul 15, 2012 1:49 pm
by fireman2118
Update?............Please!
Re: RE: The Riviera Resort Durgapur
Posted: Mon Jul 16, 2012 11:17 am
fireman2118 wrote:Update?............Please!
try this update please.
RE: Re: RE: The Riviera Resort Durgapur
Posted: Wed Jul 18, 2012 2:00 am
by fireman2118
1t02ca loaded and everything works as it should.
Outstanding work! Back in business, thanks.
Posted: Sun Jul 14, 2013 4:09 pm
by jls6214
mikel wrote:fireman2118 wrote:Update?............Please!
Would this update apply in my case? I have an Intune running the latest update for my '06 Charger SRT8, and I get the Reset TCM Adaptation failed message.
Josh
Posted: Fri May 19, 2023 5:02 pm
by TheNeonFreak
mikel wrote: Mon Jul 16, 2012 11:17 am
any updates about RESET TCM ADAPTATION FAILED. I drive a 2015 dodge Charger SXT. I wasn’t able to install the ZF8 trans tune from Hemifever for some reason. Then I notice I can’t even reset the TCM adaptation. My i3 Tuner is up-to-date as of right now. Please and thank you. Also, for additional context, the Hemifever trans tune “installed” but when I was driving for like maybe a minute or two. The car started rolling and I couldn’t push forward. Stick was on D, but it felt like I was on neutral. I had to disconnect battery (engine was still running), so I disconnected the fuse to turn off the engine, put everything back, then installed the perf trans tune from Diablosport. Everything went back to normal after that. Been using the perf trans tune for 2 years now and it’s been running good. But I just wanted better transmission tuning. I did talked to Sean from Hemifever and he gave me another version of the time, but still same thing was happening. He’s not even sure why there’s some sort of disconnection with the TCM. Not sure if there’s something I’m missing here.
Check engine code: P1DF3
Re: Transmission adaptation reset failed................WHY?
Posted: Wed May 31, 2023 11:04 am
please report the tcm adaption fail to our support team so they can get it documented and fixed.
As for the code with the custom tune, that is not something I have seen or heard of before, hard to say what may be causing it.
