Do i need custom tune?
superssguy
Post by superssguy »
Hey guys. I have a `02 Camaro SS 5.7L Man.trans....The only mods i have are Kooks LT`s & y-pipe hi-flo metal cats ,Magna-flow catback, SLP c.a.i. . Ihave a DS Predator (canned) performance tune in it. Will these light mods have any effect on the running lean/rich? Ive heard so many things about c.a.i. and how they may effect air fuel mixture. Sometimes i also get an occasional code P0138(among others having to do with the 02 sensors) circuit high voltage/heated oxygen sensor. I also have 02 simulators installed. Will a wide band 02 sensor help or will a custom tune be a better way to go? Thanks....
RE: Do i need custom tune?
yes, you need a custom tune for the longtubes at the least.
superssguy
OK but do cai`s make a car run rich?
no, but they can affect the fueling, and its a good idea to do some logging to dial them in.
CAI usually makes you run leaner, since you will be getting more airflow to the intake....
superssguy
do you know if this can cause hi Nox levels...or what does?
