Page 1 of 2
Torque Management on 05 dodge ram 1500 4.7l
Posted: Fri Oct 05, 2012 2:30 pm
by Andrew.S
My intune is upto date according to update software, i installed the diablo tune no customized parameters and from a dead stop there is still no power for about 4 sec. according to my research on these forums i believe T.M. is still enabled. What do i need to do to remove the T.M restrictions.
Re: Torque Management on 05 dodge ram 1500 4.7l
Posted: Fri Oct 05, 2012 2:32 pm
can you post up the backup and last tune written files please?
Posted: Fri Oct 05, 2012 2:36 pm
by Andrew.S
here they are.
Posted: Fri Oct 05, 2012 2:41 pm
can you post the PCM tunes please?
Posted: Fri Oct 05, 2012 2:43 pm
by Andrew.S
What do you mean by pcm tune those were taken off of the intune tune folder
heres my info.xml file if that help
Posted: Fri Oct 05, 2012 2:45 pm
thats all you have there?
please post the info.xml file as well.
Posted: Fri Oct 05, 2012 2:47 pm
by Andrew.S
Attached on last post
Posted: Tue Oct 16, 2012 12:35 pm
by Andrew.S
So I am guessing that tech support has no answer for this which is why their has been no reply at all...Thanks for the customer service.
Posted: Tue Oct 16, 2012 12:37 pm
Still waiting for the PCM tunes...
Posted: Tue Oct 16, 2012 4:43 pm
by Oldsaltydog
You need to send them the PCM tunes they are what control your engine and make it run
Posted: Wed Oct 17, 2012 4:26 pm
by Andrew.S
I have posted everything that was able to be transfered from to tuner to the computer there were no other files.
Posted: Wed Oct 17, 2012 4:46 pm
go back and restore the stock tune, then try reloading the tunes, does it ask you to update the PCM?
Posted: Wed Oct 17, 2012 8:32 pm
by Andrew.S
Ok After retuning stock tune and tuning I forget i think diablo tune here is the pcm
Posted: Wed Oct 17, 2012 8:50 pm
by Slacker
Andrew.S wrote:What do you mean by pcm tune . . .
What part of this poor guy's original question was not English enough to understand?
Posted: Fri Oct 19, 2012 1:22 pm
by Andrew.S
So all other post have a answer...is there a reason mine hasnt been pcm tunes have been uploaded and downloaded.
